Help Identify year and model
Gene N
06-25-2005 18:13:26
I am trying to find the year and model of this Case tractor that my dad bought about 3 years ago. We are in the process of overhauling the engine as well as trying to get the hydraulics to work. The serial number plate which was mounted on the side of the dash is missing. It is a gas engine; 4 speed with a Tripl-Range gear box; 3 point eagle hitch; tricycle front wheels (possibly converts to wide front), it had a power steering booster motor which has been removed. We believe the engine model is a G164 with a bore of 3 9/16". The numbers that I was able to get off of the engine and other areas are as follow: Engine-G2000 Torque Tube-G1712
Tripl-Range-G1033
Transmission Housing Cover-G1742 (F272; in smaller print under G1742).
We need to replace the crankshaft and bearings. It is becoming more apparent that we also may have to find a short block as there have been many holes patched in the crankcase from a blown rod. If more info is needed please email me. I will be posting pictures as soon as I can.
josh parks
07-10-2005 18:37:50
 Re: Help Identify year and model in reply to Gene N, 06-25-2005 18:13:26
I am 14 years old and I bought a Tiger Tractor which made in Keyser, WV sometime way back. I'm not sure of the year of the tractor or motor Its a Briggs & stratton model 14, type 202069, serial 170528. Hope you can help. thanks Josh
Tom (Ks)
06-25-2005 19:43:36
How about a 500B (dry clutch) or a 600B (Case-O-Matic) from 1958 through 1960??? Bore of 3 9/16 X 4 1/8.
Gene N
06-25-2005 20:19:28
 Re: Help Identify year and model in reply to Tom (Ks), 06-25-2005 19:43:36
There is no case-o-matic in this tractor that I am aware of. It could be either a 350 or 500, have no clue as to the year, unless the 4 8 59 stamped on the lower left side of the crankcase would be the manufacture date. I forgot to mention that the tractor has a hand and foot clutch, also has a belt pulley off the right side.
Glenn/Mn
06-26-2005 04:43:01
 Re: Help Identify year and model in reply to Gene N, 06-25-2005 20:19:28
There are differences in the apperance, can you describe the front nose part, like where are the head lights mounted 350 would be back by the dash B-series in the nose up front
Gene N
06-26-2005 10:11:22
 Re: Help Identify year and model in reply to Glenn/Mn, 06-26-2005 04:43:01
The headlights are mounted on the front of the tractor. I will be posting pictures with in the next day or 2.
Glenn/Mn
06-26-2005 11:33:38
 Re: Help Identify year and model in reply to Gene N, 06-26-2005 10:11:22
Then it be a B series tractor and if the other post is correct on the numbers pertaining to a Case 500B then that sounds correct, so it would be a 1959 and after
Gene N
07-12-2005 12:15:54
 Re: Help Identify year and model in reply to Glenn/Mn, 06-26-2005 11:33:38
Thanks for the help Glenn. I havent been able to get the pics taken loaded yet but I am going to try putting them up soon.
