Case 970 transmission
Garnet
06-24-2005 03:43:52
Hi. going to look at a case 970 for sale. the owner says it does not go into reverse. his daughter thinks a cable is broken? what should I look for when I go see it?
jim handke
06-24-2005 10:37:24
 Re: Case 970 transmission in reply to Garnet, 06-24-2005 03:43:52
If the linkage moves into reverse with no results, the reverse lockout spool might be stuck.
TripleRange
06-24-2005 09:38:11
Is it a manual or a powershift? If its a powershift it could be several things, broken cable or linkage, bad clutch plates, or a detent ball in the valve body fell out of where it was supposed to be. The valve body is on top of the trans and rather hard to disassemble. I'm no maechanic though.
