SC Oil Pump
Glenn FitzGeral
06-22-2005 20:58:18
Have any of you found the oil pump to be the cause for slightly low oil pressure on an SC CASE? My snorkel is clean and the spring on the pressure release is not broken. Is there likely anything wrong with my oil pump? Also, what pressure do you guys have on your SC's? Mine runs at about 22 lbs. I know that's not too bad but I would guess it had 5 lbs. more when it was new. I have new rod bearings. The crank shaft checked out near perfect. Also, My rocker arms are worn so some are slobbering oil and others are receiving very little oil. Have any of you reworked yours to correct this problem? How did you do it? Thanks for any responses, Glenn F.
L.Lamp
06-22-2005 21:48:04
 Re: SC Oil Pump in reply to Glenn FitzGerald, 06-22-2005 20:58:18
I have torn down a number of SC engines for rebuild and scraped others because of cracked blocks. I have had good luck on engines I have reground the cranks on and installed all new bearings. My first, a '54 carries 25lbs pressure with 10w-40 oil. My manual says 25# is max so I am happy. I have a '48 that I did not put new mains in that carries 7# at idle and barely 20# at full throttle. It has a little thump to it on rapid acceleration. I think I am going to drop the pan and try to take up the mains a little more and change the pump. I have a pump that has little wear at the drive gear end and hope that brings up the pressure. I have a '41 that got all new bearings and a reground crank. It carries 40# at full throttle and 30# at idle. The manual says it should have 35#. For the valve rockers, the amount of oil is limited by a small hole in the top of the pipe that comes up from the block and I would guess the hole to be about 1/16" but less than 1/8". Too big a hole there will lower the oil pressure. If the hole size in the pipe is this size don't worry about oiling the rockers. Do make sure the oil outlet holes in the rocker shafts are positioned according to the manual. If your engine holds 20# warm with 10w-40 or 30w, you won't improve it much with a new pump. Make sure the rocker oil tube has the right size hole first. Good Luck!!
Glenn F.
06-26-2005 16:00:08
 Re: SC Oil Pump in reply to L.Lamp, 06-22-2005 21:48:04
Thank you Mr. Lamp. My oil pressure is pretty constant at 22-23 lbs. regardless of rpm's. I'm thinkin it may not have been much better than that when it was new. Regarding the oil to the rocker arms I discovered someone had turned the pipe for the rear section upside down. The rocker arms were pressing up against the journals preventing much oil form passing. Turned it around and all is fine now. Thank you for your response. Glenn F.
