Head Castings
L.C.Grey
06-22-2005 18:11:48
I have two different cylinder heads on my two C series tractors. I know neither one is correct.
One is a 5505A. I'm guessing thats a D gas head.
The other one is a 5576A which I'm thinking must be a D LP head.
What are these two heads, and what is the proper casting number for a mid 30's C series cylinder head for use with tractor fuel?
DKase
06-22-2005 20:35:10
 Re: Head Castings in reply to L.C.Grey, 06-22-2005 18:11:48
That would be the 4570 head. The casting number is under the valve cover. You can tell it is the right one if it has the larger size spark plugs (W series Champion) and the spark plugs go straight in (90 degrees to the piston).
