What is a - 3 point Eagle hitch
Jeff-oh
06-22-2005 07:47:12
There is a guy selling a Case 400 which he says has a 3 point Eagle hitch. Is it an add-on or what makes it different from a standard cat-1 3 pt. (Or is it just advertizing to make it sound special?)
Jeff
mj
06-23-2005 07:11:18
 Re: What is a - 3 point Eagle hitch in reply to Jeff-oh, 06-22-2005 07:47:12
third party image
Here's one.....more on the link.
buckmaster 700
06-23-2005 05:57:21
it is basicly a quick hitch no balls and sockets to fight or sway chains to mess with back up hook up and go i love my eagle hitch
Ryan - WI
06-22-2005 08:26:47
Jeff, An eagle hitch is a propreitary hitch made by Case around 50-70. It looks a lot like a standard 3 pt but rather than having eyes in which the pins are slipped it has clasps. This allows you to simply get under a pin and lift up to get it into position. It works pretty slick. The arms are also more rigid and do not flex in and out to the sides. The third point is pretty much the same.
You can use 3 pt equipment with an eagle hitch.
mj
06-23-2005 06:56:24
 Re: What is a - 3 point Eagle hitch in reply to Ryan - WI, 06-22-2005 08:26:47
"You can use 3 pt equipment with an eagle hitch." .....IF the draft pin mounting width is right!
