case rear end fluid
Curtis wilson
06-21-2005 23:17:49
I have what I believe to be a 1952 case vac and I don"t know what kind of fluid to put into the tranny rearend etc. 90w? Hydrolic fluid? Everything including the three point hydrolics runs off the same fluid so I need help! Thanks Curtis
Joe (Wa)
06-22-2005 00:16:28
 Re: case rear end fluid in reply to Curtis wilson, 06-21-2005 23:17:49
For VAC 1949 & later with eagle hitch.
The factory oil for the transmission was SAE 90, takes about 7 gals, fill to the mark on the dipstick.
The factory hydraulic oil was SAE 5w, 10w or 20w motor oil depending on ambient temperature. The above motor oil or general purpose hydraulic oil is suitable. Some people use 10w-30. The hydraulic reservoir is the torque tube, that is the transition piece between the engine & the transmission, takes about 2 gals. The fill plug is 3/4" NPT located on the left side of the torque tube above a small 4 bolt flange, fill to the lip of the plug opening. The hydraulic return oil filter is in the torque tube under the above mentioned 4 bolt flange.
Joe
