continental or case engine
darrell miles
06-21-2005 16:02:13
how can determine if my case vac has a continental engine or a case engine.
Jerry W
06-23-2005 07:09:24
 Re: continental or case engine in reply to darrell miles, 06-21-2005 16:02:13
The casting number on the late Case built VAC block is VT-328.
Jerry
Jerry W
06-22-2005 05:40:15
Don't quote me because I am not at my desk but if I remember right.
A block casting number of VT-179 = Continental & a casting number in the 300's = Case.
I was told that this was done because of the war and shortage of facilities.
Jerry
C. Amick
06-22-2005 04:54:24
The engines were built by Continental to J.I. Case specifications. The Case and Continental engines are the same in the VAC.
Gene Dotson
06-21-2005 18:11:55
All VAC's used overhead valve engines. This is a Case designed engine. Continental built the engine for Case from 1942 to 1948 when Case took over the production. There are virtually no differences in the engines... Gene
Don Rudolph
06-21-2005 16:23:00
A Continental engine will be a flathead and the Case engine will be an overhead valve ( tin valve cover on the top of engine).
darrell miles
06-21-2005 17:45:03
 Re: continental or case engine in reply to Don Rudolph, 06-21-2005 16:23:00
thanks for the info. don. this is my first case vac tractor,my manual should be in a couple of days.
thanks again
darrell
