Adjusting Lifters On An SC
Glenn FitzGeral
06-21-2005 05:20:00
I am putting my SC CASE back together. I understand the lifters are to be set at .010 and .010. Is this with the engine cold and not running? Thanks, Glenn F.
Don Rudolph
06-21-2005 06:06:28
 Re: Adjusting Lifters On An SC in reply to Glenn FitzGerald, 06-21-2005 05:20:00
Glenn,
Good Luck on getting that SC running. Send some rain in this direction! Don
C. Amick
06-21-2005 05:51:34
With the engine cold and not running. It is better to adjust them a little loose than to get them too tight. If you don't have a hand crank to turn the engine with, you can put a ratchet on the big nut that's holds the belt pulley on to turn the engine.
Kirk-Tx
06-23-2005 05:42:00
 Re: Adjusting Lifters On An SC in reply to C. Amick, 06-21-2005 05:51:34
I assume this would be the same on a DC. I can remember my dad setting the tappets on older engines with the engine running. I just put the head on my DC and set them cold and not running. It was making a little rattle and I was thinking of pulling the valve cover and setting with it running. I was thinking the lifters had to be pumped up. ????? ? Thanks for any advise.
C. Amick
06-23-2005 09:40:33
 Re: Adjusting Lifters On An SC in reply to Kirk-Tx, 06-23-2005 05:42:00
The engine has solid push rods. You should also spin them around with your fingers to see if any of them are bent.
