Identify My Case
Jim Wilkinss
06-21-2005 00:07:56
We just bought an older Case tractor (40"s to 50"s) that runs great. We just don"t know what year it is (plate is missing under starter button). The front axle is adjustable.We have found the following numbers:
Engine block 6 21
Shifter plate VT207
Side of Transmission VT230 & 829
Rear End VT231 122
We would like to begin bringing it back to stock....if we knew what that was. Thanks!
Steve from PA
06-30-2005 19:47:15
 Re: Identify My Case in reply to Jim Wilkinss, 06-21-2005 00:07:56
I would have to say that it's a VAI. I agree that there have been alot of modifications made, but the front casting that the front axle mounts under has the flat front and the two holes on either side like my VAI. Just an observation.
Rick (ME.)
06-22-2005 15:15:30
Jim, The hood,grill, and gastank,are identical to the ones on my CASE VAIW tractor. The small holes in the hood by the fuel filler cap are where the grab handle brackets were bolted on.These tractors originally had grab handles for passengers to hold on to as they stood on the running boards on the VAIW.I will check my casting numbers to see if they match the ones you have.Rick
Jerry W
06-21-2005 11:28:02
Its a VAC and I cannot tell the year from the numbers given.
Jerry
Jim Wilkinss
06-21-2005 22:18:48
 Re: Identify My Case in reply to Jerry W, 06-21-2005 11:28:02
third party image
Thank you for the information that the tractor is a VAC. I have attached a photo which shows the left side of the tractor. Perhaps that will help.
I have shots from all four sides if needed.
Thanks
Jerry W
06-22-2005 05:46:29
 Re: Identify My Case in reply to Jim Wilkinss, 06-21-2005 22:18:48
It is a mid 1951 and earlier VAC but it does not look like anything I've ever seen before. The rear fenders are Ford and I suspect that the rear wheels and front axle are also.
The grill has been removed and the hood shortened. I have never seen a VAC with a flat grill except some of the tugs.
Jerry
Jim Wilkinss
06-23-2005 15:20:56
 Re: Identify My Case in reply to Jerry W, 06-22-2005 05:46:29
Thanks, Jerry. I wouldn"t have known it was a hemorphodite if you hadn"t identified it. The VAC will help me get a manual for the engine...the rest we"ll have to deal with as we go.
Jim Wilkinss
06-21-2005 22:15:55
third party image
Thanks
Jim Wilkinss
06-21-2005 22:35:43
 Re: Identify My Case in reply to Jim Wilkinss, 06-21-2005 22:15:55
third party image
Here is the front of the tractor showing the axles
Jim Wilkinss
06-21-2005 22:43:23
 Re: Identify My Case in reply to Jim Wilkinss, 06-21-2005 22:35:43
third party image
Here is the right side of the tractor
