More on 530? hydraulic problems
Jim Gundlach
06-20-2005 18:29:21
Today I changed the hydraulic filter on my 530? (That means I think it is a 530 but not absolutely sure) I topped off the hydraulic reservoir and started it up. I got the lift to work some. Put a fairly heavy boom pole on it and left it raised. Over three hours the end of the boom dropped 9 inches, from 60" above the ground to 51". I have two questions. First is this excessive leak-down? Second, and most problematic, is this. It seems that the hydraulic fluid is moving to the rear compartment during lift operation. I started off with fluid at the mark on both the front and back dipsticks. Now the back is above the mark and the front one is well down, its dipstick doesn�t pick up any. It looks like when I lower the lift, the oil returns to the rear reservoir rather than the front. Anyone have any ideas?
Roger (Mi)
06-21-2005 15:32:08
 Re: Need to replace the seal on the rockshaft pist in reply to Jim Gundlach, 06-20-2005 18:29:21
This question about transfer of hydraulic oil to the rearend on 430,530, and 630 tractors is asked about once a month. The answer is always the same. It's the seal on the rockshaft piston. You'll need to remove the rockshaft housing, remove the piston, and replace the seal. Either a Case IH dealer or after-market supplier can get the seal for you. There is a seal between the transmission and rearend, but it's ABOVE the oil levels of both. It would need to be nearly totally gone to cause significant oil transfer.
David J. Beiter
06-21-2005 08:38:17
 Re: More on 530? hydraulic problems in reply to Jim Gundlach, 06-20-2005 18:29:21
You have experienced a common problem with the whole Rock Island production Case tractors. There is a series of seals that need to be replaced. I have never done it myself, but I have replaced them on my 211B, 530, 611B, and 511B...I am sure soemone here can tell you more specifics
