What a week with Case equipment
SteveGr
06-19-2005 18:47:41
I will start off by saying that it was great time to make hay the weather was perfect and I made about 50 acres all with Case equipment 35 years old or older. I first cut the hay with a 1954 SC and a Case/ Heston Haybine. I then rolled the hay with 1948 SC with a left hand clutch pulling an older steel wheeled Case rake. I then followed this by baling with a 1954 SC4 and a Case 200 baler with a thrower. The only break down was a shear pin on the baler. Oh I forgot the bale racks were on Case running gears. It actually was enjoyable working with this older equipment, it made me appreciate the quailty of the equipment.
Greg Breisch
06-19-2005 19:46:00
 Re: What a week with Case equipment in reply to SteveGr, 06-19-2005 18:47:41
We made hay as well with the nice weather. Cut the hay with a New Holland 488 haybine using "68" 830 comfort king. Rack the hay with Case 281 rake with original case rubber tines using "67" 730 comfort king. Baled with Case 220 with bale kicker using "63" 830 eagle hitch, also wagons have case running gears. Used "54" VAC 14 to run the elevator. And used "59" 700 diesel to run the wagons.
Lamont
06-21-2005 19:41:18
 Re: What a week with Case equipment in reply to Greg Breisch, 06-19-2005 19:46:00
This is better than reading "dirty" letters that someone wrote about a wild weekend. You guys shouldn't be writing this where the general public can read it. I just got a full-body shiver and chill bumps.
Don Rudolph
06-21-2005 20:58:00
 Re: What a week with Case equipment in reply to Lamont, 06-21-2005 19:41:18
I thought I was the only crazy one to still use Case equipment! Please post some pictures!!!!!
