Backhoe Controls, wierd things happening....
Ed in Maine
06-19-2005 12:25:17
To move the bucket, you have to bump on another hyraulic lever to get the bucket lever to cause a reaction. i.e. I have to hold down on the bucket lever (nothing moves), but if I just barely put some tension on the boom lever, the bucket will curl right up. Does not have to be the boom, could just put tension on the swing pedal and that will cause it to curl. Is this a relief valve issue or an o-ring issue on the spool? The o-rings on the bucket are in the worst shape, won't even return to center from one directioin when I let go of it. It will return to center from the other direction though (the one that puts tension on the spring in the bottom of the spool). Any ideas? relief valves, o-rings, junk in the line? I replaced the filter and topped off the fluid, no change. Still has lots of power and digs good.
Case 310B, 1959
Ed
Roger (Mi)
06-21-2005 15:42:47
 Re: Bad relief on the bucket valve in reply to Ed in Maine, 06-19-2005 12:25:17
One of the reliefs on the bucket valve has a broken spring or is defective. When you move another lever, you're blocking the relief oil from the bucket valve relief to return to sump. That allow the bucket valve to work. Repair/replace the bucket valve reliefs, and you're good to go.
Ed in Maine
06-27-2005 05:14:39
 Re: Bad relief on the bucket valve in reply to Roger (Mi), 06-21-2005 15:42:47
Excellent, thanks!
Ed
