IH 574 - Bleeding The Injectors?
Dave_N_Ga
06-17-2005 19:41:32
I have an elderly neighbor with a IH 574 thats been sitting a few years. He's tried to start it and it's cranking but there's no indication of fuel reaching the cylinders.
Can anyone tell me how to properly bleed the fuel system?
I'd like to try and help him this weekend.
Thx,
Dave
L.C.Grey
06-18-2005 20:48:27
 Re: IH 574 - Bleeding The Injectors? in reply to Dave_N_Ga, 06-17-2005 19:41:32
I'm assuming that you have the fuel pump shutdown on the console straight down below the steering wheel in the run(up) position. If it is a Brittish manufacted 574 it will have a 3 position switch, stop(down)/cold start(middle)/run(up). If it is an American version it will have just stop/run
Just break loose an injector line at either the pump or the injector and look for fuel pulsing when cranking it over. If you have bubbles, it has air in the system and the lines need to be bled until you have all liquid at the injectors.
