sc hydrolic fluid fill?
kirk wannemache
06-17-2005 09:18:01
Ok, I tried to look through past messages but could not find what I was looking for. i have a case sc with the lifting bail, and I want to drain and fill the hydrolic fluid and don"t know wht fluid to use , how much, and where to drain and fill it at on the tractor. any hepl would be appreciated.
c hess
06-18-2005 12:08:32
 Re: sc hydrolic fluid fill? in reply to kirk wannemacher, 06-17-2005 09:18:01
Does your tractor have live pto. an live hydraulicks with 3 point hitch? Big difference in what type oil. Is there acylinder on left side at your feet?
c hess
06-17-2005 12:21:57
sc with lifting bail(one with pedal you steped on) USED 85-140 GEAR OILin transmission including mechanical lifting part.
kirk wannemacher
06-17-2005 16:13:23
 Re: sc hydrolic fluid fill? in reply to c hess, 06-17-2005 12:21:57
Mine has the motor lift I guess if thier is a difference. nothing that you step on, only use your hand to move lift up and down.
