case vac question
Darrell m
06-16-2005 19:01:52
Im assuming that the tublar coil i have is six volts, with no internal resistor.theres is a resistor tied in from the negative side of the coil to dist. tractor has being converted to 12 volts.if i was to install a 12 volt coil with internal resistor, would i need the extra resistor.
i plan on rewring the tractor. are there any simple wrining diagrams for these tractors.
thanks for the help
darrell
Keith-OR
06-18-2005 09:26:08
 Re: case vac question in reply to Darrell m, 06-16-2005 19:01:52
Here is a great website for anyone working on or ned info on Case Vac..HTH...Keith
Jerry W
06-16-2005 19:35:19
The internal resistored coil replaces the resistor in the wire.
Jerry
