570 3pt hitch
570 Trouble
06-16-2005 17:59:28
My 3pt has always worked fine, and all of a sudden it won't lift a 3pt finish mower properly.
When I slide the draft lever up, it stops rising as soon as it gets a load on it and creeps up very slow as if its low on oil. It also makes noise like the pump is trying to work and it goes quiet as soon as I slide the lever back down a ways. I don't have a book for it, and the only dipstick I can find to check is on top of the transmission, and it is above the full mark. My 530 has two dipsticks as the transmission is seperate from the rear end. Am I to presume this tractor is all one cavity with only one dipstick? If so, do I have a major problem such as blown seals on the internal cylinder? I also don't see any where the hyd. filter may be as it's also different than my 530. Any ideas would be appreciated as you all know how fast the grass grows in June.
Tom (Ks)
06-16-2005 19:02:25
 Re: 570 3pt hitch in reply to 570 Trouble, 06-16-2005 17:59:28
The 570 should be the same as the later 530's, a dipstick for the torque tube where the hydrulics get its oil from. The end cap for the filter should be on the left side of the touque tube also. The dipstick should be a large cap that you put a wrench on to remove (1 1/8 or 1 1/4").
