case 530 pto
Chad schreiber
06-16-2005 06:30:30
Hi, CAN ANYONE HELP? I have a case 530 with standard pto. The pto drive gear stripped all the teeth off, it also took a tooth of the driven gear. I think I can have a tooth put on the large gear but need to find the small drive gear(p/n g10675). I would like to find a used one because once I fix it I will be selling the tractor. Any help or ideas on where to look would be great. Thanks
Mapleridge
06-17-2005 17:48:01
 Re: case 530 pto in reply to Chad schreiber, 06-16-2005 06:30:30
I have had good luck with Wenger's for my 530 Case parts. The people at Worthington are also helpful. Just do a search and you can get to the sites to get the numbers and see their inventory. I would advise against welding your other gear, the teeth are usually hardened, which you will loose by welding.
Dennis/Ohio
06-17-2005 02:34:22
I"m sure gears are expensive but I"m wondering if you could list it for sale with PTO repairs optional. Let the new owner decide how he"d like the repairs done?
Best wishes, Dennis..... .
