Case 430 ck, differential side gear expansion plug
Mike Christy
06-15-2005 18:46:33
I have just been given a case 430 ck. The year and serial numbers are unknown. Ser.# over 6165270 known due to brake style. My problem is leaking oil into the brakes. It appears to me that the oil comes from the expansion plug of the differential side gear.
Can anyone tell me how to remove this plug and where might I find a replacement plug and also a replacement oil seal for the same assembly?
Any and all comments and help would be greatly appreciated...
Thanks
Roger (mi)
06-18-2005 16:29:48
 Re: Case agriculture dealer can get your parts in reply to Mike Christy, 06-15-2005 18:46:33
The expansion plug and the brake seals are available from any agriculture dealer. You'll need to remove the carrier plate to replace the seal. After removing the bolts and removing the brake housing, there will be a large phillips head screw that needs to be removed. Then, the carrier plate can be removed. Replace the seal. Be careful when putting the carrier plate back in, because the seal can catch on the pinion shaft and can be damaged. I use a tin can, cut it so that it wraps around the pinion shaft, lube it with oil, install carrier plate, then pull the tin protective shield out. Replace the phillips head screw. Reassemble with new brake linings. Good luck.
