vac brake seal
c hess
06-14-2005 18:52:55
Just started restoring dads 49 vac an found grease on both brakes. Can we pull oldseals off of shaft an install new ones without removing carrier. I also know cap can leak at end but dont think that is problem .
c hess
06-15-2005 07:50:55
 Re: vac brake seal in reply to c hess, 06-14-2005 18:52:55
Thanks for comback.
Augie
06-15-2005 07:04:24
I can't imagine how you could do it without removing the carriers. Check the pinion shaft end play before you disassemble. You'll like want to reassemble with a few less shims to take up some of the wear on the bearings and the ring/pinion gears.
WOD
06-15-2005 06:36:52
I just replaced the seals in my 51 a few months back. You have to remove the carrier to install
the new ones. Not that big of a deal you just have to be real careful when installing the new seal. It can get twisted real easy.
WOD in va
