580SuperD
Bill Barrett
06-14-2005 15:12:31
Can anyone help me with best way to change the fan belt on a Case 580 Super D. Have any of you used adjust a link belts on this type of service?
Thanks
Bill
Roger (Mi)
06-18-2005 16:41:00
 Re: Redranch is right! in reply to Bill Barrett, 06-14-2005 15:12:31
If the hydraulic pump shaft is stuck in the coupling, you can pry until the cows come home without breaking it free. Put a small air hammer against the shaft coupling as you pull, and it comes out instantly. Good luck.
Redranch
06-15-2005 06:20:25
 Re: 580SuperD in reply to Bill Barrett, 06-14-2005 15:12:31
I have a 580 C but probably the same. Just bite the bullet and put the right belt on. Take the pump mounting bolts off and you can slide it foreward enough to get the belt thru. It probably is time to grease the splines on the pump shaft anyway.
Bill Barrett
06-15-2005 19:02:33
 Re: 580SuperD in reply to Redranch, 06-15-2005 06:20:25
Thanks Red, not what I wanted to hear (LOL)
