Cutout Relay
WOD
06-14-2005 08:12:54
I noticed a cutout relay on EBAY for an Allis
Chalmers generator. It looks the same as the one on my VAC. Will this one work on my VAC?
I need one.
Thanks,
WOD
Jerry W
06-14-2005 11:01:22
 Re: Cutout Relay in reply to WOD, 06-14-2005 08:12:54
It should work if the ground polarity (+/-) is the same. The cutout will determine how the whole system is wired for polarity. You can burn them up if you wire them backwards.
Jerry
WOD
06-15-2005 06:38:32
 Re: Cutout Relay in reply to Jerry W, 06-14-2005 11:01:22
When you say ground polarity, you mean +/- ground right? My VAC is postive ground.
WOD
Jerry W
06-15-2005 20:21:36
 Re: Cutout Relay in reply to WOD, 06-15-2005 06:38:32
Yes - the cutout relay should then also be + ground. It is not hard to change the polarity of the whole tractor but it makes sense to keep it the way it is.
Jerry
