Identify hydraulic system
Jim Gundlach
06-14-2005 05:30:15
Can anyone help identify the hydraulic system on this tractor? I have posted three large, more than a meg each, pictures. The first one is: >Link
It>Link is a view from the right side of the tractor. It also includes a full view of how awful the condition of the electrical wiring is. If you zoom in on the picture and center it, the connection that caused the starting problem can be seen at the top center. The lever that is attached to a bracket bolted across the transmission housing moves what looks like a valve rod through both the front and back parts of the pump. I think this lever and whatever it activates may be causing the three point lift to not work. The second picture is: >Link
It>Link shows the high-pressure output line from the pump to the three point system. The third picture is of the three-point valve system: >Link
Thanks.
>Link
Dale O.
06-14-2005 12:31:41
 Re: Identify hydraulic system in reply to Jim Gundlach, 06-14-2005 05:30:15
Too bad it's been repainted such an ugly color! :-)
Jim Gundlach
06-14-2005 13:01:35
 Re: Identify hydraulic system in reply to Dale O., 06-14-2005 12:31:41
Mechanically it is sound, I will be removing the current paint and restoring the tractor to the correct collors.
Joe (Wa)
06-14-2005 10:18:48
The hyd return filter is under that 4 bolt flange w/rounded top that the return hyd line attaches to in the second pix.
Probably not your problem but may be contributing to poor function.
Joe
Jim Gundlach
06-14-2005 14:45:12
 Re: Identify hydraulic system in reply to Joe (Wa), 06-14-2005 10:18:48
Joe, I stopped by the local Case dealer and picked up a hydraulic fluid filter. The parts man said he had always wondered what this item was for, first time I have sold one. I don't know how long he has worked there but it suggests these filters are not changed very often. Is there anything I need to know before I go about changing this. He gave me an exploded parts view print so I know what to expect once I get on the inside. Do I have to worry about air in the system?
Joe (Wa)
06-14-2005 16:07:43
 Re: Identify hydraulic system in reply to Jim Gundlach, 06-14-2005 14:45:12
No air problem, it is on the hyd oil return. If I remember right one or more of the cover bolts is drilled all the way through into the oil cavity so put some sealer on that bolt(s)thread so it doesn't weep.
Joe
Jim Gundlach
06-14-2005 13:04:16
Joe (of Washington), Thanks, I am going by the Case dealer this evening, I'll see if I can pick up a filter and replace it.
Old Rusty
06-14-2005 06:38:25
You have either a 430 or 530 draft-o-matic hyd system. Would have to know more as to how it is acting to help with why it won't work. The lever going to the Valve under the fuel tank moves the spool in the remote valve. The three point will not work if this is not in the center position.
Jim Gundlach
06-14-2005 07:08:23
 Re: Identify hydraulic system in reply to Old Rusty, 06-14-2005 06:38:25
Old Rusty, Thanks, I think you hit the nail on the head, I have only been trying it with the lever all the way forward or all the way back, assumed middle was nothing important.
Jim Gundlach
06-14-2005 19:10:23
 Re: Identify hydraulic system in reply to Jim Gundlach, 06-14-2005 07:08:23
Turns out front lever position is not the problem. The lift simply does not work when the lift control is moved up and down. It was acting like this when I first looked at the tractor and the seller had a mechanic out working on the lift and I worked it before I bought it. I had not bothered with the lift for the first couple of weeks that I had the tractor, spent that time working on the leaking fuel line and then air in the injectors and then the starter connection problem. I am going ahead and replace the filter and if that does not fix it, I guess the next thing is to check the relief valve unless somebody has a better idea. Oil levels are fine. Both front and back are within 1/8 inch of the line on the dip sticks.
