Clutch Oil from Engine On L
cheg
06-11-2005 20:03:39
Where does the engine oil on a "L" wet clutch come from? The crankshaft on my L has a hole that is offset from the center. I assume this is where the oil comes off the rear main. The hole seems solid to me. Does it make a 90 degree turn somewhere in the hole? Does the oil circulate back into the engine or stay in the clutch compartment?
Camboted
06-12-2005 03:46:19
 Re: Clutch Oil from Engine On L in reply to cheg, 06-11-2005 20:03:39
The hole is tapped into the pressure line in the crankshaft of the tractor. YOU CAN TEST IT WITH AN AIR COMPRESSER. It should take air at 30#+. If it is plugged clean it or you will ruin your clutch. The clutch housing retains about a quart of oil, so for a complete engine oil change you need to drain the sump as well, and add a extra quart. The oil returns to the engine by a lip on the top of the oil pan which catches the oil as it is lifted up by the rotating flywheel.
