What is this?
David Donaldson
06-11-2005 16:18:56
I volunteer at a summer camp. They have this old tractor that I would like to find out more about. It is a four cylinder gas two wheel drive. Looks like about a 40hp. It has VT-328(possibly 326) stamped on the left side of the engine block. CVT 596 on the back end. It has four speeds in forward, one reverse. It has VT 161 on the shifter plate. It does not have hydraulics but it does have a belt drive PTO on the right side.
I have photos I can email. Please email any info to [email protected]
wheat straw
06-12-2005 20:02:25
 Re: What is this? in reply to David Donaldson, 06-11-2005 16:18:56
David, It appears to me to have 28 inch rear clamp on cast wheels on short axils and a non- adjustable wide front end. If I'm seeing it right that makes it a VA which is a standard tread modle.
Wheat Straw
David Donaldson
06-12-2005 10:48:43
Thanks Guys, a wealth of knowledge as usual.
Now for the $64,000 question: what is she worth? We are in Southern Ontario (Canada). Last time we had her running, about a year ago, we had to bump-start. She would crank, just not enough juice in the battery to start. She is stored inside. I did not notice a serial plate, will take another look next time I'm up there. I have more detailed pictures if anyone is interested.
Once I have an idea on price, I will be advertising her. Thanks again.
Jerry W
06-12-2005 11:00:44
 Re: What is this? in reply to David Donaldson, 06-12-2005 10:48:43
In my area that tractor would bring $400 to a $800 US at auction. No Eagle hitch really hurts it. There is on at my local Ford dealer almost identical to this one and maybe a little rougher. He wants $1000 for it and it has been for 3 months. I offered him $500 and so far he has refused.
Jerry
Joe (Wa)
06-12-2005 09:30:54
Tractor is VA series. VT328 is VA series 124 cid engine block, about 20 pto HP (VT326 is the water pump impeller for some VA series). VT596 is the torque tube used on VA series serial nr 5370499 to 5458563, that would make it 1949-1950. VT161 is standard shifter cover plate for most VA series.
Joe
John H-WI
06-11-2005 17:48:33
Its an industrial version of the VAC, smallest tractor in the Case line at that time. The VAC was built in several different models. Is the serial number plate gone from the dash? Some of the VAC experts may be able to pin down the year of manufacture from the part numbers you have listed.
