Flambeau Red
Kirk-Tx
06-10-2005 18:23:37
I searched the archives for paint codes for my DC. I found NAPA 99l 3727,Dupont 016DH, Ditzler 71282, PPG 70137 or 71282 & Martin Seymore "crossfire" 53A 3727. Armed with this information I went shopping. I struck out at Carquest paint specialty store, local paint store, Tractor Supply & Case IH dealer(IH original dealer). The paint stores told me to bring a sample & they would mix to match. I am afraid that the 50 year old paint would not be a good sample to match. Any suggestions?
BobV
06-11-2005 15:04:00
 Re: Flambeau Red in reply to Kirk-Tx, 06-10-2005 18:23:37
Kirk, I went thru the same problem and looked at the paint codes.... old numbers I went to a Dupont supplier checked numbers.... same thing then I told him the paint name was Flambeau Red, he knew the color from a GM car I bought a qt. just to prove wright/wrong it matchs perfectly I found a spot that was protected under the gage area to test the match. The type of paint is Centari 75195A,cost code, Code 5885, GM year 1994
F-I-T
06-11-2005 13:06:17
third party image
This is the PPG Acrylic Enamel code 71282 in the DAR line that I used on my VAC. It was VERY close if not identical to any sample I could locate under areas protected by years of grease. I was very happy with it.
I have some other photos on my wevsite as well.
Frank
JW
06-10-2005 20:53:35
Corprate Orange from Agco is supposed to be very close
Jim Gundlach
06-10-2005 20:10:23
For what it is worth, the list sponsor lists the following:
(CASE) Paint, 1 Quart-Flambeau Red - From TISCO, providing OEM quality. High Strength air dry enamel with Alklyd resins to assure durability. Fade resistant, smooth uniform film characteristics. (Part No: TP140LF-QT) $18.74
cleatusj
06-10-2005 19:37:17
TSC only had it in gals.
Kirk-Tx
06-10-2005 19:38:55
 Re: Flambeau Red in reply to cleatusj, 06-10-2005 19:37:17
Is the paint acrylic enamel?
jason(ma)
06-10-2005 18:43:40
I HAVE NOT BOUGHT FLAMBEAU RED YET. but.... what I did for my allis g was to go out and buy a bunch of pints of paint and compare them to my tractor's paint. I feel this was better than a "custom mix" don't want new paint to look faded from day one. Here is a link to Rod(NH) ppg list which ppg's 3116, 70138 and 71282
Cleatusj
06-10-2005 18:33:26
Tractor supply in Benbrook, tx. stocks it. It is called JI CASE RED.
Kirk-Tx
06-10-2005 19:00:26
 Re: Flambeau Red in reply to Cleatusj, 06-10-2005 18:33:26
Thanks guys.That gives me something else to try.
oliverfan
06-10-2005 20:32:36
 Re: Flambeau Red in reply to Kirk-Tx, 06-10-2005 19:00:26
I like the VanSickle paint. I have used Case Flambeau red as well as Oliver Green. You can buy it in spray cans, quarts, and gallon cans.
Call 800-677-2468 and ask them who handles their paint near where you live.
