Case-O-Matic low pressure problem
Pat Traynor
10-04-1999 08:21:41
I no longer have clutch pressure on model 530.
Used to have 110# at control valve and 30# at converter pressure regulator, as per manual.
I have 165# at filter. Now only get 60# at control valve only when pedal is depressed, and 0# at converter reg. When pedal is released, press. instantly drops to 0#. Dissasembled both units and all parts work freely. New gaskets made each time. Only item not dissaembled was the control valve ball, spring, and orifice plug. Oil level is FULL. What has happened? Anyone had experience with this type problem?
Larry
10-10-1999 20:00:00
 Re: Case-O-Matic low pressure problem in reply to Pat Traynor, 10-04-1999 08:21:41
I had a 400 Case-O-Matic that had about the same problem.It turned out that the oil cooler was plugged up. if I remember right the oil goes from the pump to the front of the tractor.There it goes through the filter and the bottom of the radiator to be cooled then back to the rest of the system.Back flush the oil cooler and see if that works.let me know how it turns out.
Pat T.
10-13-1999 10:55:27
 Re: Re: Case-O-Matic low pressure problem in reply to Larry, 10-10-1999 20:00:00
Thank you, Thank You, Thank You!!!
Unbelievable that 165# won't go thru one way, but 60# of water press. will unplug it in the other direction. Wish I had flushed it into a bucket so I could have seen what was plugging it.
I now have too much press. at the control valve.
Over 160#, where the manual wants 105-120#.
Have to take out some washers behind the spring in press. regulator I guess. Thought about checking there for blockage but line was too stiff to get out of the control valve tee, and decided it was very improbable that it could be plugged, having a filter in the line. Thanks again, Larry.
