Early dry clutch model?
Jim Gundlach
06-09-2005 17:24:33
I'm trying to read the I&T shop manual about trouble-shooting the hydraulic system on my 530?. It has the statement "...pump out of gear (on early dry clutch models)." I don't have a serial number but I have reason to believe that is is between 8262800 and 8297800 based on a print out of the fuel system I got from the local Case dealer. Anybody know how I can tell if I have an early dry clutch model? If I do, how do I check to see if the pump is in gear? Also, anybody know of a better shop manual?
Tom (Ks)
06-09-2005 17:52:44
 Re: Early dry clutch model? in reply to Jim Gundlach, 06-09-2005 17:24:33
From what I read, they are talking about the ones up to 1963. Early eagle hitch tractors would have a lever that you push in or pull out. Look at the front of your selective control valves (on top of the torque tube), you might see a small flat lever sticking straight out the front. Your manual should have a picture of this a few pages further on.
Jim Gundlach
06-09-2005 19:54:04
 Re: Early dry clutch model? in reply to Tom (Ks), 06-09-2005 17:52:44
Thanks Tom, I will look it over in the morning and see if I can decide what I have.
