Case 885
Dan J
06-09-2005 11:31:40
Just picked up a Case 885 Diesel with a front loader and can't seem to find much info on it. What can you guys tell me about it? Hp, year etc. Thanks, Dan
Aussietractor
06-10-2005 23:22:55
 Re: Case 885 in reply to Dan J, 06-09-2005 11:31:40
I've got an 885. The decal on it reads "CASE DAVID BROWN 885". Great little tractor, pulls real well in low RPM, and only sips the fuel.
Aussietractor
06-10-2005 23:38:06
 Re: Case 885 in reply to Aussietractor, 06-10-2005 23:22:55
Further to my previous post, some info on the 885. In Australia they were listed as- 3 cyl 164 ci engine developing 51 HP, 43.2 PTO HP,37 drawbar HP,120Nm of torque @1400 RPM, Years of production 1971 to 1980, max oil flow 27 litres/min @2500 psi. They have a two speed live PTO through 2 stage clutch with 12f and 4r gears. Hope this helps you.
JohnF2020
06-10-2005 07:19:06
Just to add---they were an excellent little tractor which was capable of "punching way above their weight".WE had one here(David Brown)in Ireland for many years and it often pulled 6 ton carts back in the early eighties.Their is a club if you would like to see pictures of more and learn some more info.Type in David Brown tractor club on a serch engine and you will find it.
Regards,
John
Johnf2020
06-10-2005 07:13:41
Hi Dan.Your 885 is actualy a David Brown built in Meltham England between 1973 and 1982.It is 48hp.
David Brown tractors were bought by Tenneco which was the owner of Case.Part of the new agreement was that David Brown tractors were often sold as Case outside of Europe.
