PTO removal on a 1952 CASE Model D
Martin Pisz
06-08-2005 14:46:15
third party image
Hi
I want to take off the PTO with cover to replace the badly leaking gasket
around the pto itself. How can I pull it out. Don't want to take the
whole tractor in as I don't have a truck or trailer to move it. I have
taken part of it out put the forks shown in picutres below prevent the PTO
from comming out. I can't even put the PTO back in anymore. Can can I
remove the thing. It's an old 1952 CASE Model D tractor. Any clue how to
remove it. The pictures show what I mean. Follow the links below.
This picutre shows the forks, moving them back in is impossible as they go
against the disk way inside. Can't even put the whole assembly back in, is
there a trick.
Link
This is just the overall picutre to get the idea of the tractor
Link
Lever shown in this one moves the forks back and forth.
Link
Thanks for any help.
Paul f
06-09-2005 05:19:50
 Re: PTO removal on a 1952 CASE Model D in reply to Martin Pisz, 06-08-2005 14:46:15
Make sure the PTO Clutch is engaged before you try to remove the shaft and clutch plates...else wise getting them lined up and back in is a major piece of frustration...
Martin Pisz
06-09-2005 08:01:55
 Re: PTO removal on a 1952 CASE Model D in reply to Paul f, 06-09-2005 05:19:50
Ok I think I'm past that stage. I did not engage the clutch. But as you can see from the picutres, I think I got some of it disconected. Oh well.. I guess this will be an extersice in patiance.
Camboted
06-08-2005 18:50:30
third party image
Your picture is so large I cannot see it well, but you must remove the forks and shaft, be careful that the keys don't fall into the sump! You'll have to remove the top cover to do this. I'll post the instructions, but they may be too small to read. You might copy them and expand the view. Hope it helps. LOL!
Martin Pisz
06-09-2005 08:04:41
 Re: PTO removal on a 1952 CASE Model D in reply to Camboted, 06-08-2005 18:50:30
Thank you very much for the information. I beleive this is the information I am looking for. However, when I copy and expand the picutre it becomes blotchy and unreadable. Can you scan that again and with much larger size. You can email me the image directly to [email protected]. I think you may have found my solution, if I can read it. Thank you very very much.
Paul f
06-10-2005 05:51:47
 Re: PTO removal on a 1952 CASE Model D in reply to Martin Pisz, 06-09-2005 08:04:41
Check your email
