730 Case wont start without ether
Durk (OH)
06-07-2005 10:57:22
Looking at a 1964 730 diesel that needs a shot of ether to start on first start of the day , then its fine to start rest of day. what would cause this? has new injectors and rebuilt injector pump. any help would be appreciated.
Durk(OH)
JIm McVay
06-07-2005 14:55:50
 Re: 730 Case wont start without ether in reply to Durk (OH), 06-07-2005 10:57:22
Do a compression check and clean precombustion chambers. If compression is low the air is not getting hot enough to ignite the diesel.
CNESLER
06-07-2005 14:54:12
Durk
Worn sleeves and pistons will cause these tractors to need a little starting fluid to start the days work.
That said it could still give you years of service depending on how you use you tractor.
Good Luck
CNESLER
