Cleaning a Case SC Air cleaner.
Joel V
06-07-2005 08:19:38
Hello all! Is there a good way to clean out an SC air cleaner? In mine there is all kinds of junk, grease-dirt etc. in the screen mesh and I really don't see a way to disassemble the thing to clean it out. Could I possibly soak it something to loosen it up? Any other ideas?
Joel V
06-08-2005 08:51:16
 Re: Cleaning a Case SC Air cleaner. in reply to Joel V, 06-07-2005 08:19:38
Thanks guys!!
JSTPA
06-07-2005 12:36:32
I took mine all the way apart, of course mine was basically plugged. To get it apart I took the bowl off the bottom, then if you look around the base of the air cleaner you'll see some tabs that hold the metal piece in place, I just carefully pushed in on those tabs and worked it out, then I was able to get the screens out and clean them good. Hope this helps, jstpa
C. Amick
06-07-2005 11:11:32
We always just used gasoline to soak it in and an air hose to blow it out after the gasoline had loosened stuff up.
