780 David Brown cluch noise
Mike Sasser
06-07-2005 06:40:49
When I let the clutch out in neutral, there is a lot (loud) of noise coming from the mid section of the tractor. When it is in gear the noise is not as noticeable. Clutch was replaced last year and is working fine. The noise came rather quick What might this be?
Also, the hydraulics works fine while the system is cool. It takes high RPMs to get the hitch to raise once it heats up. There is no water in the fluid. What would cause this?
Thanks,
Mike
Mike Sasser
06-09-2005 07:37:54
 Re: 780 David Brown cluch noise in reply to Mike Sasser, 06-07-2005 06:40:49
Could this be the throw-out bearing?
