430 Rockshaft Piston Seals
Dew
06-05-2005 18:45:29
I am looking for the seals for my 430 Case Rockshaft Piston. My parts manual for this SN tractor shows a different picture from what I actually have. My piston (PN G1404) has 2 metal piston rings and 1 rubber seal. My local Case dealer has no listing for this type of piston (I was able to obtain the metal piston rings). Can anybody out there help me with the part number for this rubber seal? The piston PN is G1404 and the rockshaft housing PN is A35510. Thanks.
Joe Young
06-06-2005 03:56:06
 Re: 430 Rockshaft Piston Seals in reply to Dew, 06-05-2005 18:45:29
I have two parts manuals for the 430 series...
The first is for years 1960-1964 (SN less than 8262800) shows two views. The full assembly...PISTON (w/steel ring) has been superceded by part number A36438 (which is the newer style piston assembly). However the view lists the parts for the older style which are:
G4803 RING - piston (steel)
G46889 "O" RING - (piston w/steel ring)
G46899 RING - seal(piston w/steel ring)
The newer parts catalog SN 826800 thru 8297800 does not show the older piston assembly at all. You might also check a parts manual for a late model 300 series.
Joe
Dew
06-06-2005 18:30:54
 Re: 430 Rockshaft Piston Seals in reply to Joe Young, 06-06-2005 03:56:06
Joe:
Thanks for the info. I'll try the parts you suggest.
