Model VAC, oil in radiator,
Joe (CT)
06-05-2005 13:07:23
Just picked up a model vac and we got it to run good but there was about a cup or two of used motor oil in the radiator. We also found an old rusted can of cracked block sealer in tool compartment. There is no antifreeze in oilpan. Would this be a bad head gasket or is this a cracked block. Thanks for any ideas
mike's600
06-05-2005 17:25:10
 Re: Model VAC, oil in radiator, in reply to Joe (CT), 06-05-2005 13:07:23
I got my Vac running today, no oil presure ,checked the pump( it's good), spun bearing i guess. Sounds like you had better luck. Your head gasket is blown between the oil return and water jacket. good luck should be easy fix.
