DC Gear Oil Level
Russell Dewsnup
06-04-2005 17:25:21
I had to replace the seal on the belt pulley shaft. When I did I lost some gear oil. I replaced the oil I had lost but I am not sure how full the differential case should be. The seal was leaking when I got the tractor so I don't know how much has been lost. My operators and service manuals indicate that it holds 10 1/2 gallons total. Short of draining all the oil and refilling the differential is there any way to know if the case is full. The oil in the housing looks good and clean and doesn't need to be replaced. I can see that the chains and gears are in oil. Can any one tell me a way of telling if the housing is full enough? Thanks a bunch in advance.
dctom
06-04-2005 17:59:04
 Re: DC Gear Oil Level in reply to Russell Dewsnup, 06-04-2005 17:25:21
russ, look on right side at the rear, should be a small plug there, that is the oil level tom
