A bad day with the 530
Jim Gundlach
06-04-2005 16:51:48
This morning I replaced the fuel line and secondary fuel filter and in so doing I got air in the injector system. Pulled the lines off the injectors and cranked the engine for a while, actually quite a while, until the lines shot a nice solid jet of fuel, reconnected and it still would not start. I got puffs of white vapor, not really smoke out the exhaust but no starting. Now, the starter quit working. When I turn the key nothing happens. When I short the poles on the starter, the starter motor turns but it does not engage the engine. I'm charging the battery back up in the hopes that that is it, but in general it is been one real frustrating day with this Case. My wife just said "Do you thing the seller got rid of it at the right time?"
Oh, also, discovered that there is a leak in the fuel tank as well.
R.McGuffin
06-06-2005 19:05:04
 Re: A bad day with the 530 in reply to Jim Gundlach, 06-04-2005 16:51:48
If you take the fuel tank off, you can probably fix the leak with a little JB Weld. I had to do this on my 430 and it worked well.
big orange
06-04-2005 17:25:16
I commented on the post below.As far as the leak,is it a hole or crack?If a hole you may be able to take a small sheet metal screw and plug it,seal the outside with silicone.
Jim Gundlach
06-04-2005 17:46:45
 Re: A bad day with the 530 in reply to big orange, 06-04-2005 17:25:16
I'll have to take the tank off to see. It looks like it is at or around the right front mounting bolt. I found it after I got the fuel line leak fixed. The fuel line leaked so much that it obscured the tank leak. I'm more worried about getting the thing to start. Thanks
Joe (Wa)
06-04-2005 18:12:35
 Re: A bad day with the 530 in reply to Jim Gundlach, 06-04-2005 17:46:45
Ah try it tomorrow when the battery is fully charged, low battery is probably not cranking it fast enough to get the cylinder ignition temperature/pressure up.
Joe
