oil filter
John Hajek
06-04-2005 08:53:50
Help ! Need information as to who makes a replacement oil filter to take the place of a CASE A 36136 filter ,spin type.
Tractor vac serial # 5062483.
Dealers in So. California are not able to help me. Tractor is a 1946 model.
THANKS JOHN
C. Amick
06-06-2005 09:23:25
 Re: oil filter in reply to John Hajek, 06-04-2005 08:53:50
I buy mine at NAPA. It's also the same filter that fits the 300 Series tractors. Make sure the hollow metal stem on the filter engine housing is in place when you remove the old filter. After you loosen the old filter, you will have to pull the old filter up and off of the stem.
Joe (Wa)
06-04-2005 10:02:02
Wix 51101, same as Napa 1101. Napa 1104 is suitable also. Go to the link and type in vt3589 (a36136 is a later cross-ref p/n), for specs.
Joe
Duner Wi
06-04-2005 09:58:08
Hastings LF 405 is the cross #. Any decent Napa or Carquest should be of help.
