David Brown 880 diesel Won't Start
BJS
06-02-2005 19:55:52
I have tried the following things and still no luck. New fuel lift pump, rebuilt the injectors, fuel is reaching the injectors nuts. It will not even fire on ether, sprayed directly into the intake manifold. I mowed grass and shut off the tractor, next day, it would not start. The engine timing and fuel injection pump timing have never been touched. Valves are only a couple thousands off. Any help would be greatly appreciated. Thanks.
Elmer
06-03-2005 11:36:41
 Re: David Brown 880 diesel Won't Start in reply to BJS, 06-02-2005 19:55:52
There is a snap ring that hold the injection pump drive up in place. It can shear off and the drive will drop about 1/4 inch and being a helical cut gear the timing will move enought hat the engine will not run. Remove the injection pump and check the snap ring.
