630 case-o-matic hydraulic pump
STS01
06-01-2005 22:18:59
my 630 has a bad hydraulic pump, where is it, I have no manual. I will probably just tear into it, because it is a simple trans, but any guidance would be apprieciated.
Roger (Mi)
06-02-2005 03:50:01
 Re: hydraulic pump under torgue tube cover in reply to STS01, 06-01-2005 22:18:59
You'll see the hydraulic lines and control levers going to the cover on top of the torque tube. The hydraulic pump for the Case-O-Matic and a seperate pump for the hydraulics are attached to the underside of that cover. When the cover is removed the pumps will come with it. Remember, always check simple things first, filters, oil levels, etc. Good luck!
