forgot email
RiddleMN
06-01-2005 07:25:26
Forgot email adress
Les
06-02-2005 02:25:30
 Re: forgot email in reply to RiddleMN, 06-01-2005 07:25:26
One of the first things you'll want to do is get a shorter bar and chain for that chainsaw. No bigger trees than what you're going to cut, there's no need for a 28" bar (that's what it's called, at least around here). The longer it is, the more likely it is to find its way into some dirt and you'll be sharpening it and it's a LONG way around when the bar is that long. A 20" bar is plenty long enough and a 16 would probably be even better for you.
Joe (Wa)
06-02-2005 12:02:25
 Re: forgot email in reply to Les, 06-02-2005 02:25:30
I certainly agree with Les on the chainsaw size you need to mow down them saplins you mentioned. I could understand a 30" bar if you had to log off a couple of square miles of banana trees, specially if they was growing above the timberline.
Joe
