LA main brgs
Dinno
05-31-2005 16:09:13
I have a LA crank that has just been turned 10 under. My question is do i need 10 under brgs or can i remove shims to make up the diff? thanks for any help
L.Lamp
06-01-2005 20:35:17
 Re: LA main brgs in reply to Dinno, 05-31-2005 16:09:13
If you can't get new .010 under bearings somewhere, check with Don Livingston. I have had SC Main shells remanufactured by a source he has. You can get them any size you want.
AllanC
05-31-2005 22:16:02
You should have .10 under bearings, if you just renove shims the bearings are shightly egg shaped and won't wear well or hold oil pressure.
