No 4th gear (VAC)
jdman(MO)
05-31-2005 15:03:46
Finaaly able to take a test drive and found I have no 4th gear. It shifts into the slot, but just acts like it is in neutral. All other gears and reverse are normal. Any suggestions...Russ
Augie
05-31-2005 17:05:39
 Re: No 4th gear (VAC) in reply to jdman(MO), 05-31-2005 15:03:46
Pull the top cover off the tranny and take a look inside. Stripped gear, bent shifter fork, smoked or mis-adjusted clutch are all possibilities.
jdman(MO)
05-31-2005 20:00:16
 Re: No 4th gear (VAC) in reply to Augie, 05-31-2005 17:05:39
Bad news stripped gears (2), only about 1 tooth left of 4th gear. Russ
Augie
05-31-2005 21:42:30
 Re: No 4th gear (VAC) in reply to jdman(MO), 05-31-2005 20:00:16
I've got a couple of VAC's for parts. Let me know if you decide to fix yours. I should have what you need for cheap $$$.
jdman(MO)
05-31-2005 21:50:46
 Re: No 4th gear (VAC) in reply to Augie, 05-31-2005 21:42:30
Thanks I may decide to tear into it, but not this week. Russ
rgorange
05-31-2005 17:29:34
What year is it? Is it possible that this tractor came from the factory with steel wheels? During WWII rubber tires were hard to get so tractors came with steel wheels and high gear diabled somehow. Not sure how case accomplished that... I"m sure somebody else out there knows. I think some tractor manaufacturers just had a plate to block the shifter from being placed in high gear. When the tractor was converted to rubber tires the plate was removed. Case may have done this differently.
