Case D what???
Jeff w/ an H
05-31-2005 13:12:22
Hello,
What is the difference between a D, DC, DC3, DC4. I am trying to figure out which is which, but get confused. I see pictures of some that all look alike. Any thoughts?
C. Amick
06-03-2005 09:24:51
 Re: Case D what??? in reply to Jeff w/ an H, 05-31-2005 13:12:22
To further confuse you, there are also DO's, DI's, DV's, DCS's, etc (see link below).
Gene Dotson
05-31-2005 18:37:11
The "D" is the standard version with 26 inch rear tires tires on non adjustable hubs and the front axle was non adjustable and mounted directly below the radiator. "DC" and "DC3" are the same tractor and is a row crop with adjustable rear axle with 38 inch rear tires and can come with an adjutable wide front, two wheel tricycle or a single front wheel. These all had the front wheels located ahead of the front of the tractor. The "DC4" had 38 inch rear tires with adjustable rear axles and a non adjustable wide front axle mounted under the radiator, like the "D"...Gene
Nedd
06-01-2005 08:16:05
 Re: Case D what??? in reply to Gene Dotson, 05-31-2005 18:37:11
I thought that the DC3 was for DC's with 3 pt/eagle hitches. Am I wrong?
C. Amick
06-03-2005 09:08:13
 Re: Case D what??? in reply to Nedd, 06-01-2005 08:16:05
No, I don't think the designation has anything to do with the Eagle Hitch.
