Case 430 stalls
Bernard M
05-30-2005 07:07:37
I have a gasoline 1963 Case 430. I recently changed spark plugs , installed a new coil, electronic ignition kit to replace the points and a new radiator as part of refurbishing it (coil and ign. kit are Ignitors from this YT site). I start the tractor, and if I let it idle to 1000 rpm, it eventually shuts down and won't restart until I let it cool down (coolant temperature gauge reads a max temp. of 180-190F when running; I don't think the fan belt slips). Next, I'm thinking about replacing my wires on spark plugs and Coil-to-distributor. Any thoughts, anyone?
Ed in Maine
05-31-2005 04:23:47
 Re: Case 430 stalls in reply to Bernard M, 05-30-2005 07:07:37
If you are sure fuel and spark are not the issue, I would check compression in each cyl after is stalls out. Could be a heat related head gasket problem? Does it do anything wierd before it shuts down, white smoke or missing? Let us know what you find.
Ed
case poor in pa
05-30-2005 14:46:08
put your old coil back on if it was good before you replaced it.. try that.. maybe a bad new condenser to
Bernard M
05-30-2005 17:57:14
 Re: Case 430 stalls in reply to case poor in pa, 05-30-2005 14:46:08
Thanks. However, this is why I replaced the coil when I got the tractor, because it was also stalling then...
Doc Larry
05-30-2005 19:12:41
 Re: Case 430 stalls in reply to Bernard M, 05-30-2005 17:57:14
Can we assume that when the engine stalls and won't start, you've checked fuel supply versus spark, and are certain this is an electrical problem and not a fuel problem?
Larry
Bernard M
05-31-2005 06:13:10
 Re: Case 430 stalls in reply to Doc Larry, 05-30-2005 19:12:41
Ed; Larry;
Thanks for your answers... well, I plowed for an hour or so yesterday evening, and it went well. After I wrote my initial post, I checked the fuel and the tank was almost empty (down to the recessed compartment at fuel tank bottom. There was frost on the carburetor outlet to cylinders at the last stall (mixture too lean?). I'll make sure I have more than enough gas, and will check the fuel filter so it does not create a restriction. I sure hope it's as easy as this! Thanks again for the support - will let y'all know...
Joe Stef
06-04-2005 03:43:23
 Re: Case 430 stalls in reply to Bernard M, 05-31-2005 06:13:10
Hello, I have a similar problem. I'll be cutting fields for over an hour and the tractor just putters to a stop. Usually I wait a 1/2 hr and it starts. Now it won't start at all.(1969 case 430 gas)
