Help My Dip-stick fell in!!!
Robert (Gremlin
05-29-2005 18:19:20
I had been using a dip stick to check the oil level in the gear box in the rear of my 155 and I dropped the stick into the box. Unfortunately it is made of aluminum so a magnet is of no help. I tried to remove the axel to get into the side of the housing. I had no trouble with the wheel and the break but after I unbolted the axel from the tractor it would not come off. (It slid out a bit but that was all) How do I get in?
Cleatusj
06-03-2005 17:54:53
 Re: Help My Dip-stick fell in!!! in reply to Robert (Gremlin), 05-29-2005 18:19:20
Get a flashlite and look inside her, you should see a nut on the end of the axel, it must be removed before axel will slide out. Or drain oil and use long needle nose pliers.
Jeff w/ an H
05-31-2005 13:18:45
Oh, come on, somebody's gotta have a sense of humor here.
