sleeve removal 580 [188] diesel
steve's paint
05-28-2005 19:09:05
Okay, can any of you pro"s out there tell me how to get the sleeve"s out of the block?? with out taking the block out!!!! they have never out in 30+ years, and i can"t be the only one to try this before!! thanks in advance..... ....steve
David in SC
05-29-2005 02:41:47
 Re: sleeve removal 580 [188] diesel in reply to steve's paint, 05-28-2005 19:09:05
Steve,
On my 207 I made a puller using some heavy 1" square stock. Two pieces for the top with a very large heavy washer welded between the two. Weld them leaving a large enough space so it straddles the block outside the sleeve surface. Then dropped a piece of 3/4" allthread through the hole into the bottom of sleeve where I had a homemade piece of stock resting on the crank.(on a rag of course) The bottom piece was solid stock turned just slightly smaller than the base of the sleeve so as to not scar the bore when pulling. Turned a lip on it so it would center itself in sleeve. Had a nut to match the allthread welded to the base piece. Put the allthread down through the washer in top piece, screw into base piece, then put nut on top of top piece and start turning nut to pull sleeve. Also shot with PB Blaster for 2 days prior. Also had to square off 2 sides of my base piece so slide it down into the sleeve because there is not enough clearance on top of crank to slide anything in. Not pretty, but it worked.
Good Luck,
David in SC
