Mag to Distributor
Trains39
05-27-2005 12:53:30
I have seen models of DCs with a distributor. Does anyone known if it is possible to install one on a 1948 DC that currently has a mag?
Doug Franks
05-28-2005 13:34:31
 Re: Mag to Distributor in reply to Trains39, 05-27-2005 12:53:30
I have one of these dis. If you are interested email me direct [email protected]
jal-SD
05-27-2005 13:22:48
We've converted several DC's & SC's to distributor, as we couldn't get parts for the mags any more. The right-angle Delco's work best. They will bolt right up to the flange. Allis & IH both used them, the last one we got came from a WD or WC, don't know Allis well, & didn't look that close at the salvage yard. The flat ones work, too, but the right angle ones give you a little more room. They will work w/12V, just get a 12V coil, points don't seem to care if you have a 12V coil. Our I-H dealer doesn't even have to look up the number in the book when you go in for points, there are so many Delco's in our part of the world. (My $0.02 worth. jal-SD)
Trains39
05-27-2005 14:09:19
 Re: Mag to Distributor in reply to jal-SD, 05-27-2005 13:22:48
Do you have a part number for the distributor assembly?
Paul f
05-28-2005 05:55:54
 Re: Mag to Distributor in reply to Trains39, 05-27-2005 14:09:19
Right angle mount distributor and component numbers
Delco-Remy Distibutor Mdl 1111411
Points Condenser Rotor Cap
Standard Igniton Part # DR-2227XP DR-60X DR158 DR-405
B-W Part # A40V G102A D10 C150
JGarner
05-27-2005 14:06:08
I am seeing rebuilt and used mags on ebay frequently. I would shy away from a used mag, but are rebuilts reliable?
I think I would prefer to stay with a mag if the tractor came that way. In my way of thinking they are less trouble; ie, no points to file and gap, no condensor to go bad. I was a happy boy when electronic ignition replaced these things!!
Trains39
05-27-2005 14:10:55
 Re: Mag to Distributor in reply to JGarner, 05-27-2005 14:06:08
You can get an electronic replacement for the points and condenser. So would it not make sense to change over from mag to distributor?
Trains39
05-27-2005 14:04:55
Does anyone know where I can get these parts? Very little is available in my area.
Paul f
05-27-2005 13:14:34
All DCs came with Mags...However, over the years people have replaced mags with distributors from Farmall and A/Cs. Mine has a right angle drive and uses a delco remy distributor...still 6 v but it runs well. Points condensor rotor and cap are readily available at a auto parts store (mine had them in stock)
