david brown hydraulic problem - elmer can you help
shawn howard
05-27-2005 10:21:33
I have a David Brown Tractor. 53 hp diesel. It runs great is reliable, except that the power lift/hydraulics get very "tired" after the tractor runs over a few minutes. I have drained and changed the hydraulic oil once, and it did not help at all. The hydraulic oil is very milky looking. I do know that the boot on the shifter is broken and may be letting in water, but I thought changing the oil out would have fixed this problem, if only temporatily, but it didn"t. I hear that you are the expert on this matter. Your help would be greatly appreciated.
Thanks,
Elmer
05-28-2005 06:50:33
 Re: david brown hydraulic problem - elmer can you in reply to shawn howard, 05-27-2005 10:21:33
Usually when the hydraulic systems drops off after a few minutes operation, it is due to a wore hydraulic pump. If you need one i can supply them.
Jim Chambers
06-08-2005 04:12:34
 Re: david brown hydraulic problem - elmer can you in reply to Elmer, 05-28-2005 06:50:33
I have an 880 and had the same sort of problem. The solution was to remove the two spool valves on the right hand side that are under a steel plate that has two large philips head screws. The valve closest to the mudguard has a small orifice and screen that becomes partially blocked. Has to be cleaned quite a few times once you change the oil as it keeps picking up dirt.
shawn howard
05-28-2005 07:08:42
about how much do they cost, and could you send a copy of the part of the manual that covers that repair. My experience of working on tractors is limited to 8N fords.
thanks again
Elmer
05-31-2005 02:59:22
 Re: david brown hydraulic problem - elmer can you in reply to shawn howard, 05-28-2005 07:08:42
First we better make sure which tractor this is. Is it the 990 Selectamatic. If so the pump is about $450.00 in American funds. If it is the Implematic the pump is no longer available. But i do have a guy working on producing the pieces to build a new one. May be another month yet. I can provide the manual too.
Sean in Tn
05-27-2005 20:42:24
There is a filter at the bottom of the transmission. It helped when I cleaned it on my David Brown
