Russ, you have to have a restriction, I was just trying to get a sense of how much. When the lever is in neutral, the pump is simply circulating sump to sump via the control valve, the return passages in the control block, the return tubing, and the return filter. There is probably about 4 psi pump pressure if there is no restriction in any of the above. Look on the bottom of the control block you see a hex plug. Under the plug is the lift check valve with a spring. To overcome the spring tension and open that valve and admit pressure to the piston requires about 8 psi. I would check the easiest things first. 1. The tube that routes the return oil from the control block back to the torque tube has compression fittings. The fittings connect to a 90� elbow on each end. If a ferrule has slipped, the tube may have been pushed all the way in to the back of the elbow restricting the flow. 2. Take the return filter out and try running it that way. 3. Take the control block apart and check control valve and passages . On the lower right side of the piston /rock shaft housing is a 5/16� tube that leads back to the torque tube. That tube vents the under side of the piston when the arms are raised. It also conveys piston oil leakage and excess grease from the rock shaft back to the torque tube. If that tube plugs, there will be grease buildup under the piston that will cause problems lowering the arms. I can�t see anyway that this is connected to your present problem but it is worth checking before you have to get into the control block. Just disconnect the fitting and run the hitch up & down several times. You should get air and probably some oil and grease on the piston down stroke. Joe
