311b starts but won't run
andy s
05-26-2005 21:21:59
motor tries to start then dies i replaced the old carb with a new zenith replaced the exhaust manifold, points cap/rotor wires coil checked and adjusted everything i could think of any suggestions?
Joe (Wa)
05-27-2005 10:06:24
 Re: 311b starts but won't run in reply to andy s, 05-26-2005 21:21:59
Could be any one of a dozen things. Check for fuel at the carb, spark at a spark plug, etc. Try to narrow it down to fuel or spark. Run a hot wire from the battery to the coil to by-pass the ignition switch. Don't leave the wire on there very long unless the engine is running.
Joe
Texas Denny
05-27-2005 07:51:33
Sounds like a fuel obtruction in tank or line.
shawnspeed
05-28-2005 08:22:53
 Re: 311b starts but won't run in reply to Texas Denny, 05-27-2005 07:51:33
Check to see if it has a ballist resistor inline running to the distributor. My 730 had that problem when I bought it. you would turn the key to the start position and it would start,and as soon as the switch went to the run position, the engine would die. I finnaly removed the resistor,and just repace the points a little more often. shawn
andy s
05-28-2005 12:34:03
 Re: 311b starts but won't run in reply to shawnspeed, 05-28-2005 08:22:53
put a resisitor in line changed points started on first turn now does any one know the capacities of the trans/diff weight of oil/ thanks a bunch every one
Jens Barclay
05-29-2005 18:28:06
 Re: 311b starts but won't run in reply to andy s, 05-28-2005 12:34:03
Trans oil holds 5 gallons on 311. Use SAE 90. The torque tube holds 12 quarts. Use SAE 10W-30 oil. The crankcase holds 5 quarts with filter. O'Rellys auto parts has the oil filters. I have the original owners manual for the 300 series. Let me know if you need any toher info.
